How much HP 1/8 time?
Car: 1985 Z-28 2003 chevy Silverado Z71
Engine: was 305 LG4 now 355 HO
Transmission: TH700r4
Axle/Gears: posi 373
How much Hp do you guys think I am running I just swapped my Lg4 with 181,000 miles on it with a totaly rebulit 0 miles 350/355? Stock heads the block came out of a 1974 Z-28 250 hp the heads where cleaned/rebuilt and I put new lifter. There is only a 1/8 mile track around where I am from what do you guys think I’ll run on it?
MOD’s
1985 Camaro Z-28
350 bored .030 over (355)
Balanced
HEI distributor
Edelbrock Performer intake
Comp cam Lift .447/.447 Duration 290/290
Pacesetter shorttie headers from jet hot / y-pip coated
High flow Magna flow cat
3 inch piping flow master 80 series muffler
308 gears with posi
K @ N Xstream air cleaner
Ac Delco plugs Megafire wires
Air inductions hood
180 thermostat
MOD’s
1985 Camaro Z-28
Balanced
HEI distributor
308 gears with posi
Air inductions hood
180 thermostat
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
What heads?
what pistons?
what crank?
what rods?
what is duration @ .050?
What carb?
Loose the Performer and go with Performer RPM or Stealth!
with my guess of 9.5cr and stock length rods/stroke, and a decent guessat that cam lift/duration, you should be maybe 300hp at the flywheel, meaning 240 to the wheels(estimating 20% loss), and theoretically you would do a 13.7 max with that much power, if you dead hooked and all.
what pistons?
what crank?
what rods?
What carb?
Thanks for the reply!!! The heads/piston/crank/rods I don’t know what kind they are. Duration is .050 carb is the stock Rochester q-jet I had it rebuilt a year ago intake is an Edelbrock RPM I said Performer I was wrong I thought it was the same thing for some reason.
