need info on ford police cars
Car: '95 Trans- Am
Engine: 5.7, Baby
Since u guys seem to be the best car guys on the net, I decided to ask this here. I was just wandering what do the older crown vic police cars have unique? My uncle is gonna sell me the 5.0 from one of his. He also said I can take anything else I want, what do these cars have in them? Is there anything else that might be valuable driveshaft or anything?
1 Post
Car: 91' Pontiac Firebird
If it's like the 9C1 Caprice, it's basically a stock V8 car with a bit stiffer suspension. No magic "cop chip" or any other such nonsense. it may or may not have a limited slip diff.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
So its a Ford? If it is those are the absolute worst piles of crap ever. Nothing on them is worth a damn at all. Ford doesn't know how to build cars. All of their new models are Mazda's.
You could take the drivetrain and sell it. Maybe take the swaybars and sell those too. But most people that have Crown Vics don't have them for their power or handling prowess.
Car: '95 Trans- Am
Engine: 5.7, Baby
the reason i am asking is that I am gonna do an engine swap on my '96 mustang so it will have a v-8. but while i am at it, if the springs, or sway bars will fit and are performance pieces as compared to mine, then I need to get everything from it. I might even get the rear end as well.
That's just like Ford. Start with a 4,000 pound slug of a sedan. Wedge in a couple of 400 pound officers and gear, then "power" it with a 300-ish inch engine. The only thing worse is the newer design, powered by a 260-ish inch engine. No wonder they start blowing oil at 40K miles.
On the up-side, at least you'll have a real engine for your 'Stang. The modular engines are probably best left to the Clown Dics, Grandma Queers, and salvage yards.
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Originally posted by ME Leigh
Mazdas
Mazdas
Car: 1983 G20 Chevy
Transmission: 4L60
Or the E-250 shop van where I work, 4.2 V6 with NO Low-speed torque, an Automatic, and Tall gears. It can barely hold 60 MPH on the Highway with the A/C on.
My stock 175 HP 305 Chevy Van could have made it a speck in the mirrors, rather quickly.
Car: '95 Trans- Am
Engine: 5.7, Baby
Thanks for all ur help guys. In light of new evidence from stangnet, these police 5.0's are only 160hp. My v-6 almost has that, so thats still a waste of time. Im just gonna have to find a 5.0 from a mustang to continue my swap.
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by SSC
Just speaking of police cars in general including GM ones. The only things upgraded on them are the cooling system and suspension.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
depending on the year of the motor, it's probably a roller block and whatnot. It is a low output version of the mustang motor (ie, not the 225HP version), that's mostly due to cam though.
but yea, you're asking about souping up a mustang on a camaro website Take a walk, go find a mustang website.
Actually my brother has a crown vic, go to crownvic.us and ask about the cop motor, haha...
Originally posted by Fast355
I don't know for sure on the ford, but on the 9C1 caprice. The following are changed speedometer, charging system, bigger cam, bigger injectors, different chip (GM Caprice) with NO Speed Limiter and improved HP, exhaust system, different tires, the transmission is setup to take the abuse and shift 3-4 @ WOT, a different gear ratio.
As for the original question, you're probably far better off using the 302 as a basis to build a stout engine as compared to the Romeo engines. You'll probably find a lot more help at www.corral.net Some of those guys are pretty decent.
1 Post
The ONLY difference in the Speedo is it has "certified" printed on it
ALL LT1 Caprices got the 140 amp alternator
With the exception of an external oil cooler, the engine and computer are EXACTLY the same as the non-cop caprice, with the exception of a 130 MPH speed limiter(yes, 130, NOT unlimited). No magic cop program that gives you 800 extra HP, no special cam, nothing.
the exhaust is EXACTLY the same as the LT1 Civi caprice
Ok, I'll give you the cop tires. they are speed rated, but that is the only difference, and even that was optional on the cop cars.
ALL Lt1 Caprices have the same trans, and all have the "Vette" servo
ALL Lt1 Caprices have 3.08 rear ends, NOT all have Posi, not even all Cop cars got posi
As far as the 9C1 VS the P71 Crown Vic, the caprice has better acceleration, and better braking, but the Vic handles and rides better.
Don't believe me? Ask these guys: http://www.impalassforum.com/cgi-bin...i?action=intro
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by Coach Hawk
Ok, NONE of these are true. I HAVE a '94 9C1 Caprice, and have done pleanty of research on the subject.
The 9C1 frame is a full boxed frame that is unitized, very similar to my older G-Vans.
The 9C1 350 TBI car had the L98 cam, bigger injectors, dual exhaust, 3.42 rear end, a 700r4 that could do a 3-4 shift @ WOT, silicon hoses, the POLICE chip IS DIFFERENT than a civilian 350 car.
The cam, exhaust, and injectors are different so IT HAS TO BE DIFFERENT, NO QUESTION ABOUT IT.
I have read BOTH the standard civie L05 350 chip and the 9C1 350 chip, they ARE DIFFERENT. The L03 chip for the 9C1 is different than a regular L03 chip as well. I haven't looked into the LB4 4.3 chip, but it is probably different as well. On the TBI cars they got rid of the limiter.
I have seen the test results from the slalom on a P71, the caprice will out-slalom it. Hell I have test results from a 1976 G-Van that out slalomed a newer P71, as it was able to make almost 65 MPH in the handling test as they called it back then..
Car: '95 Trans- Am
Engine: 5.7, Baby
Originally posted by ljnowell
Very sound advice. Face it, you are asking questions about the sworn enemy to most of the poeple here, and with good reason. Mustangs spanked thirdgens way too much for people here to like fords.
No, apparently ur my enemy. Most people on these boards have no problem helping someone with another american car. Incase u missed the memo, imports are the enemy. I'm just trying to find info so I can take them out.
Transmission: 5 spd
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
That would be why they outsell GM in almost every category.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Car: 2005 BMW 545i
Engine: 4.4L N62B44
and why am I the enemy?
And if you have a '94 SEO (or any 10-bolt) and haven't already done so, you might want to check the rear cover gasket. The factory installed a gasket with no outer oil return holes for the outboard bearings. FelPro makes a replacement with the correct cutouts. If you've eaten rear wheel bearings and wondered why, now you know.
Car: '95 Trans- Am
Engine: 5.7, Baby
ahh yes, sorry i meant ricers in general that could possibly exclude you. The motor is free, but to get it to the same power as the mustang 5.0, it would still take around the same amount of money as buying a used one. I'm gonna call around some junkyards here and try to find an explorer 5.0, with there heads and intake, it'll be a much better starting point.
Does the Explorer 302 have heavier mains? Are the heads better? If not, the free engine might be just as good a starting point. A decent cam, a little head work, and you sould have something. As I mentioned, check out the Corral.net. Some of the people over there know their stuff pretty well. I haven't played with Fords (other than repairing them for everyone else) since the '70s.
Then why did the 91-96 9c1 kick the living **** out of the ford until 97.....when gm didn’t offer the b-body anymore?
I think his point was...the ford police cars are nothing special
Guest
Posts: n/a
Originally posted by Vader
and lots of little amenities that plain old B-Cars don't have, not to mention the Fords.
People wonder why they went to Fords... well... thank GM for that, they decided they didnt need to sell the cars anymore.
Hey, we got this here unit-body front-driver 6 holer smaller car that'll do ya just as good, we promise!
Guess they weren't buyin that one.
There's a few 'special' Fords running around out there, but thats not what you are going to get or find. You are going to find a run of the mill 4.6 dog, thats what you will find. Exploder may not be a bad idea I suppose, going to build up the motor? Some of the crate motors dont look too bad if you ask me. There's a ton of selection, just ditch the cam, dont like any of them they offer.
with the smaller engine
Man I'm bored, google in Ford Crown Bi...errr... Vic police interceptor. It'll kick ya from cvpi.com to fleet.ford.com to some button to click, but I found this funny:
"Government's 5-Star front crash test safety rating - Crown Victoria has received the government's highest 5-Star crash test safety rating for the driver and front passenger for 10 years in a row (1996-2005)"
Good thing they didnt test the rear. Oh wait...
"Tested in 75-mph rear-end crash - No other car in the world is tested to this standard!"
Doesnt say what happened. Maybe they did address it though:
"Industry-first optional Fire Suppression System"
Originally posted by madmax
Uhh... smaller? Ever seen a 4.sux? Damn thing is almost as big as a BBC.
Stick with the Windsor. Oh, wait - This is a GM board. Go ahead, go nuts with the modular engine. It'll hold together - Really.
