Underdrive pulleys....worth it?
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Looking at some underdrive March Power/Amp series pulleys. Question is, are they worth it? All the pulleys are smaller than the stock units correct? Anybody got any track times or dyno numbers with it. Thanks for the help.
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: Underdrive pulleys....worth it?
Engine: 4++,350 & 305 CIs
they work! make sure they are made out of aluminum for the most bang for your buck..... less weight.. if the alt pully is bigger than your stock pulley dont use it if your just driving around a lot.. your batt will be dead fast .. I run the SLP crank pulley only..
yea, well, i have a 383 HSR, heads, cam, so, you think they will help out more than a stock engine?
That is just my theory though, lets see what some of the other guys think.
Car: 91 Formula WS6
Transmission: five speed
I just got these particular March pulleys (GM amp series) for my 136k mile LB9 5spd Formula and at the same time did 1.6 Summit roller tip rockers and new valvesprings. Hello! Definitely perked up the car.
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
What is the difference between the power/amp set and just the regular set. If I do not have a huge stereo, would I need the power/amp ones? I am guessing they modify them for big stereos and do not let as much power loose as the regular march underdrive pulleys.
Car: 91 Formula WS6
I have the regular March pulleys on my 3rd gen road race car - it does not have to run headlights, tunes, etc. Your street car does, and I think March designed these pulleys for street cars. I have head too many complaints from folks using the regular ones about headlights dimming, etc. I am very happy with the amp series on my street car.
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
Sean, March CLAIMS that with the Power and Amp series you will have full power at idle (whether you want to believe that or not is up to you). For street use, it would probably be better to go with the power and amp series just to be safe. Or you could go with the ASD underdrive pulleys which tell you at exactly what RPMs you get a full charge (750 RPM, 900 RPM, 1000 RPM, etc.)
Also, to the thread starter... there was an article on gmhightechperformance where they put March power and amp pullies, an edelbrock catback, and a jet chip on a 5.7 TBI chevy truck and it gained 21 RWHP. I know the SBC chevy trucks are alittle different than our f-bodies but catbacks dont yield much, and everyone who uses a off the shelf chip seems to get slower, so that leads me to believe that the pullies were responsible for a good portion of that.
EDIT: It seems they added an intake to that truck as well. So that might be some of the gain right there. But i would still think the UD were atleast 5 HP of that gain...
Engine: LB9, LB9
So I guess you get better power from the regular pullies, but the power/amp series dont give as much power, but make it safe for the street.
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I have a March Power set on my 305 TBI, its a crank pulley and an alt. pulley. The crank pulley is significantly smaller than stock, very light too. The alt. pulley is larger than stock but is twice as heavy as stock. To make for the difference I guess.
At and idle of 700 rpm I have a voltage of 12 volts, and can push a 1000 watt amp with no problem. I really noticed a difference shifting into 2 second gear also. I like mine, hope this helps.
Car: 1983 G20 Chevy
Transmission: 4L60
On my G20s 305, I used a crank pulley from a 4.3 astro that bolted on fine and was about 5" in diameter compared to the stock 305s near 7". The lights dim slightly at idle, but I don't have any charging problems at idle either. Dual A/C, stereo, electric fans, etc, but I have a 130 amp alternator. There is a noticeable power difference, especially on a Hot summer day with the A/C on, fuel economy improved some as well especially with the A/C on.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
another chevy high performance or w/e magazine picked up some rwhp on a LT1 with the pulleys.. i dont recall how much overall but i think it was close to 10 if not over that on a mustang dyno.
dyno'd 218 stock... with catback, maf sensor tuning, cai intake, and pulleys, (could be something else but i dont have the article here with me) but those mods were good for a total of over 260rwhp on a mustang dyno
ambainb
04-25-2016 09:21 PM
bigjay89gta
10-15-2015 08:04 AM
Navy8125
08-22-2015 07:13 PM
