queston about comp roller lifters
Car: 84 Z-28 Camaro
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I just got a set of comp's hyd. roller lifters P/N 853-16,when I got them, they were shrinked weaped, still in the box, new,I was just wondering, are you supposted to be able to push down the pushrod seat area like standerd lifters, because I can't seem to be able to do it to these (they move alittle...like a fingernail's thickness, but not like the set of flat lifters I have laying around), also the number printed on the body of the lifter is 26605, if that helps, I was just wondering if comp may have mess up packing them
They have some grease in them from the mfg process.
Clean them before you do anything with them; soak them in lacquer thiner or something.
Don't worry about how far you can push the push rod seat in, it's irrelevant. If it moves they'll be fine.
no green
01-09-2016 09:22 PM
KO1
16
10-15-2015 05:00 PM
