tickin noise..after new base install.. injectors?
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
well i got a new edelbrock high-flow base put on my tpi and now i have a good tickin noise and it picks up when i rev.....im thinkin it has to do with the injectors firing, but not sure....all i know is that it never did it befor the base swap and now its there. i can feel it in the AFPR but cant feel it in the injectors anywear!! is this a big deal? i dont want to mess anythin up....i dont like the noise tho i want it to stop!! help please
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Listen to all the injectors using a screwdriver.
Some will click, some wont.
Like a beyond microscopic particle on the pintle seat will make the injector not click.
The ticking is normal, all fuel injectors do it, some moreso than others. If there are no other issues, I would not worry about it.
Drive a turbo 60 with Motron 60# injectors. My TTA sounds like a sewing machine :-)
later
Jeremy
later
Jeremy
mrestrictrplate
09-21-2015 11:24 AM
