will removing CC carb and distributor affect converter lockup??
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
will taking out the CC carb and distributor from my sport coupe affect the converter lockup function? I would want to think so but i'm not sure..any input?
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
yes, for the ECM to lockup the TCC it needs a TPS input, im not sure but i believe it needs a RPM input too.
I was thinking of one of those b&m/tci lock up kit with the dash mounted control.
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
have this on my car...http://bowtieoverdrives.com/catalog/...AT&CATID=OA1A3
i just cut the lock up wire on my truck and use a toggle switch. It has 36 inch tires and would lock up too soon with a 3.08 rear.
THANK YOU hoogabooga!! that is exactly along the lines of what i'm looking for..just hook it up and forget it.
1992 Trans Am
05-10-2023 07:19 PM
