How many teeth on my flywheel?
Car: 1988 Camaro
Engine: 5.7 liter motor
Transmission: Four speed automatic
I'm looking to get a high-torque mini starter (200 ft. lb.), but I don't know how many teeth my flywheel has.
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Some mini starters have an aluminum adapter block to accept either the 168 or 153 flywheels. Straight across bolt pattern only.
A similar starter is seen in the following post.
https://www.thirdgen.org/techbb2/sho...ight+staggered
This good post also contains information concerning the straight and staggered bolt patterns on the starters. If you know what bolt pattern is on your current starter is, then it may (or may not) tell you what your flywheel situation is.
If you still can't figure it out from there, get under the car and start counting.
Best-
S-D
Best-
S-D
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
i'm pretty sure that all thirdgens are 153 tooth flywheels and flexplates. i tried to run a 163 tooth and i couldnt seal a header because it was hitting the stock sized starter.
if thats not clear, you can go here:
https://www.thirdgen.org/techbb2/sho...hreadid=257009
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If you can't count, but can use a tape measure,
12.75" diameter = 153 teeth
14.00" diameter = 168 teeth
monte87cortez
09-26-2015 09:10 PM
