aluminum heads
aluminum heads
What is the difference between the 14101128 aluminum heads and the 10088113 heads
14101128...86-87...350..........Aluminum, 58cc, angle plug
10088113...88-up...350..........Aluminum, 58cc, angle plug, raised
"D" port exhaust, 1.94"/1.5" valves
taken from this site:
http://www.mortec.com/castnum.htm
The 113 is obviously the newer and probably improved design. I'm not sure on the exact improvements though.
Yeah I run the 113 heads and I was reading some old hotrod stuff and saw the numbers, and wondered what the diff was..........
ambainb
04-25-2016 09:21 PM
