max valve lift for zz4 ?
Car: 1987 IROC
Engine: zz4 short block
I would like to swap my current cam for something more aggressive. My current setup consists of a zz4 short block, trick flow heads (old style) and a HR-276-2s-12 cam, .488 .509, 214 and 222 duration. Spoke with comp cams today and was told that a cam with more lift or duration might cause clearence problems, ie.. valve to piston contact. Anyone running a zz4 with a larger cam? Opinions welcome....
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If you stay below .575-ish, you probably won't have V-P clearance issues. Besides, it's not really the max lift thats all that important when it comes to VP clearance. Valve timing has a far greater role and the only way to know for sure whether or not you will or will not have issues is to dummy it up and test it out.
I used a set of soft springs and a dial indicator.
Hotrodboba400
12-10-2019 07:07 PM
