cutting fuel lines on framerail...how to flare???
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
im going to cut the fuel lines down on the framerail when i swap in the HSR. what type of flaring tool do i need so i can attach the flexible stainless lines to them after i cut them???
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Just for reference you can go straight from where the hardlines end, get a $5 converter to take it to -6AN, then go straight to the HSR fuel rails. Its much easier, but maybe its not the look you want?
If you want to cut your fuel rails, get the tool from autozone (free to rent) and flare them yourself. I'm not sure where you can get the fittings you need, but summit has nearly everything. Good luck!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The flare tools you rent are usually for 45 degree SAE flares. To do AN fittings you'll need a 37 degree flare too, which is a bit harder to find.
Car: 1991 Z28
Engine: 383
i know i cant adapt straight from the hard lines...i already have all the fittings for that but while im at it and putting so much into this motor i want to make it look as best as i can and cutting the lines looks MUCH cleaner.
im going to flare them my self but i need to know what flares to use (what tool to rent/buy)
i have the adapters to go from the stock 14mm and 16mm fittings to -6AN so basically i need to flare the lines just like from the factory but down on the frame rails.
1 Post
Car: 86 T/A
Engine: HSR 355
Oh good idea, maybe I'll try that. Is stock size SAE (I can't recall) ? If so then that 45* flare tool should work.
1 Post
Car: 86 T/A
Engine: HSR 355
http://www.autozone.com/in_our_store...ing/tubing.htm
The question is if 45* works with the stock threaded lines.
1 Post
Car: 86 T/A
Engine: HSR 355
He has all the fittings and hose he needs, he just needs to reflare the lines up further then use the stock fittings.
Car: 1991 Z28
Engine: 383
i have a double flaring tool but are we sure the stock flares are 45 degrees or are they 90?
heres a pic i snapped at the stock flares (ive already cut off the hard vent line )
its a little blurry but you can see it doesnt make a "v" at the top but more like a "t"
stock is singinaw (sp?) flare. the only "tool" that you can get for that is the gm j-tool or see your mac dealer for the flaring tool kit. (it's the same one the dealer has- well some dealers) any way it is the hydrolic hand pump one works great for what you are doing
what i did was I bought the an pipe ends and I belive the 45 deg is what I used (can't remember)
as for the factory ends If you must have them. you can go to auto zone and get the pre flared pipe
Car: 1991 Z28
Engine: 383
ok well i might go that route and get rid of the factory sagniaw ends altogether.
what fitting would i need to connect my -6AN hose ends to the hard lines on the frame rails? i looked at jegs and summit but couldnt find what im looking for (since i dont exactly know what it is im looking for).
Car: 1991 Z28
Engine: 383
well thats what ill do then. i just need to get 4 straight -6AN hose ends and those tubes and sleeves and get rid of my adapters, 2 180 degree bends, and 2 90 degree bends. man i love wasting money...
theshackle
03-05-2017 06:37 PM
AkDrifted
08-17-2015 07:45 PM
