sensor under plenum?
Car: '89 5spd GTA
Engine: 305(LB9) TPI
Axle/Gears: Borg-Warner 3.42
Just pulled my plenum off my '89 LB9 (305TPI) and noticed a sensor attached to the bottom. What is this? Looks like it may be a temp sensor of some kind.
Give that man a cigar!
On TPI motors I've often relocated it over to the air filter box- it gets heat-soaked real easy in the middle of the than aluminum oven. I don't actually take it out- I just buy another one, install it over near the air filter and extend the wires over to it. Doesn't make any more power but the engine ran more consistently hot vs. cold.
Car: '89 5spd GTA
Thanks Damon, Air filter box is gone in place of open K&N, but I was just wondering
1nastygta
09-24-2015 08:58 AM
