HV vs SV Oil Pumps
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
HV vs SV Oil Pumps
I ordered a standard pressure, high volume oil pump for my l98, and now after reading a few posts around I guess I should have went with a standard volume. It shouldnt sap all that much power though. Any idea if its a big difference?
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I went with a Standard volume standard pressure on my 383. High Volume is if you have a bigger pan with more oil capasity. You dont want to run the pan dry.
standard pump is all 99% of the applications would ever require. weld the pick up, or buy the up graded pump wit hthe bolt on pick up. i like the mr gasket #26 spring as do alot of others here.
Car: 1983 G20 Chevy
Transmission: 4L60
I like the HV with the #26 spring, but then again that is just me. Works well with the 5 quart truck pans that I use. An oil change is 7 quarts for me. 2 in the filter and 5 in the pan.
I think about thew only time extra volume is necessary is if there is oil needed for an accessory, like valve spring coolers or a turbocharger bearing. It really doesn't hurt, except to possibly hit the relief valve with more volume than normal.
ambainb
04-25-2016 09:21 PM
toronto formula
11-10-2015 06:17 AM
Navy8125
08-21-2015 09:32 AM
