Washing Off Engine
Washing Off Engine
What is the proper way to wash out the engine...I just want to spray some water to get all that damn dirt and crap off of it. Should I wash it and let dry...wash it while it runs, crank and then turn off?
1987 Camaro Sport Coupe 305 V8 LG4-rebuilt-All Stock.
Future Mods: Flowmaster American Thunder 3 in. Cat-back, Catco High Flow Catalytic Converter, Hooker Super Comp Shorty Headers Jet Hot coated, K&N Air Cleaner, CompCam 264H, White Paint, IROC wheels, Alpine CDM-7871 CD player, Polk Audio speakers, Grant GT Rally Steering wheel,New Fuel Pump, Ground Effects, B&M Megashifter
1 Post
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
well what i do is start up the car in the morning (cold). i hurry up to get to the car wash place. i go ahead and pop the hood. start off by washing the the whole car(allowing time for the engine to cool off slighty, even though it's not even above 100* mark). MAKE SURE THE ENGINE IS COLD. then i go ahead and wash the engine with the motor off, of course. when i'm done close the hood start it up and drive home.
[This message has been edited by mystikkal_69 (edited December 03, 2001).]
1 Post
Car: 99 Formula
Axle/Gears: 342
Don't spray cool water on a block that isn't running and is still warm, you run the risk of cracking the block. What I do, is my some GUNK spray or Engine Brite, let it soak and then rinse off with just running water no pressure. I just tried using laundry detergent that was recommended by Vader, worked good. I find the mountain fresh workds really well.
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Gas= $20
GM GOODWRENCH 350
KN AIRFILTER
I prefer the spring morning scent, its magical. LOL!
Yeah, laundry detergent works great, the hard part is explaining it to other people, they just kinda look at you. After a while though they admit they tried it, and it worked.
Car: '87 Z
Engine: 355 in the works
So what kinda laudry detergent? The powder kind or the liquid? Where can I get 'GUNK spray' or 'Engine Brite', at a Pep Boys or something?
1 Post
Car: 99 Formula
Axle/Gears: 342
<font face="Verdana, Arial" size="2">Originally posted by hy-po-ny:
engine gunk? save your cash and just use a good ole scrub brush and warm water
</font>
</font>
Another great product to get at Walmart is Castro Superclean. I just spray it on my engine, let it sit and just rinse it off. You can use this stuff to clean just about anything.
Just goto a carwash and hose it off. I have done this 100's of times with no ill effect.
What happens when you drive you car in the rain and splash in a puddle. Cold water splashes on an engine and that doesn't crack it.
Leave your engine running and try to avoid spraying water directly at the distributor and air intake.
Happy washing....
Happy washing....
1 Post
Car: 99 Formula
Axle/Gears: 342
<font face="Verdana, Arial" size="2">Originally posted by a73camaro:
Happy washing.... </font>
BULL$HIT
There have been 6-8 times where I have sprayed the distributor a little to directly and killed the engine. Then I proceeded to wash the stalled engine for a couple of more minutes. NO CRACKS.
An engine block is a little more robust than a piece of glass.
[This message has been edited by a73camaro (edited December 04, 2001).]
So nothing will hurt it if I drive it about 50-100 feet to the sprinkler hose and hose it off, right? I'll wash the whole car first and then the engine.
Can I crank the car if the engine compartment is still wet?
I hand wash my car, so i don't take it to the car wash.
1 Post
Car: 99 Formula
Axle/Gears: 342
BULL$HIT
[This message has been edited by a73camaro (edited December 04, 2001).]</font>
BULL$HIT
<font face="Verdana, Arial" size="2">Originally posted by calypso:
Another great product to get at Walmart is Castro Superclean. I just spray it on my engine, let it sit and just rinse it off. You can use this stuff to clean just about anything. </font>
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Car: 4
Engine: 6
Transmission: 5
I use the Engine Bright and quarter car wash method, with no special precautions of any kind; just drive over to the car wash, stop at Auto Zone or wherever on the way to pick up the diesel fuel in a spray can, and have at it. Been doing this now for ... on second thought let's not go there, let's just say it's been since long before F cars reached their third generation. I haven't broken any castings yet, although I did kill a distributor once (points type) and had to dry it out before I could go home.
I wash all my engines this way regularly, and of course right before major work whenever possible.
ICON Motorsports
ICON Motorsports
<font face="Verdana, Arial" size="2">Originally posted by Mark A Shields:
I don't mean the block will crack in half or anything, but go ahead run the risk of getting a cracked block.
</font>
</font>
Have you ever see a cracked block from washing it while it was warm?!?!?!
1 Post
Car: 99 Formula
Axle/Gears: 342
Then don't drive the car. You could stall the engine and hit a puddle or a rain storm and crack you block from splashing water.
Have you ever see a cracked block from washing it while it was warm?!?!?!</font>
Castrol Superclean is the best product I have ever used. I buy it in the gallon jugs. When I was tearing down a 400 Pontiac for my 75 Firebird, I used a big bucket filled with the stuff. It took the gunk off of parts that had sat in grease and gunk since 1972 in a matter of minutes. One word of advice though, WEAR GLOVES! I made the mistake of not doing that when I washed the parts and got bad chemical burns on my hands.
1975 Firebird - Pontiac 350, TH350, 27k original miles, rustbucket, ongoing resto project
1992 Firebird - 305 TBI, 700R4, sport appearance package, t-tops, flaming red, 89k miles, Weiand 360 air cleaner assembly, CAT Power Engine Parts race underdrive pulleys, more to come....
<font face="Verdana, Arial" size="2">Originally posted by lonsal:
Castrol suprclean does take he paint off te car...and so does a 2000 psi powerwasher with superclean..to bad I learned the hard way
[/B]</font>
[/B]</font>
