can i cut here? (pics)
would it be ok (structuraly) if i cut about a 6x6 hole here (under the charcoal canister and airfilter) ? or if i do do yall think i should maybe frame it with some metal to keep if stronger?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
[This message has been edited by breathment (edited December 01, 2001).]
1 Post
Car: 91 Red Sled
I bet he wants to run a cold air pickup for the motor. That's what I would do with a 6"x6" hole .
I'm pretty sure you can cut it away. If you want you could just make it strong again by adding a thicker steal plate to the edge but I'm almost SURE you don't need to do that. That point doesn't support the radiator, doesn't do anything for the structure of the car, engine cradle, tranny crossmember or struts so go ahead and cut.
I planned on removing it when I finish my aluminum air box.
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I think you will be fine. I mean all that sheet metal is, is a battery tray anyways.... I doubt it has any structural duties - and even if it does, you aren't cutting the entire thing out. I actually am thinking about cutting mine up a bit right there, and running a cold air setup as well. My future plans call for a Ram Air hood, but seeing as I don't see the funds being available anytime soon, I might hook up a cold air setup through that area for now.... Once a hole is cut in that tray, you can set up a nice cold air setup that will even have a ramming effect if a nice inlet is attached near the air dam.
I say go for it......
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
1987 GTA L98 MD8
My GTA
<font face="Verdana, Arial" size="2">Originally posted by JPrevost:
[B]I bet he wants to run a cold air pickup for the motor. That's what I would do with a 6"x6" hole .
B]</font>
B]</font>
Im gonna try and get a 3.5" exhaust pipe and get a 90* mandrel bend in it, then run it through the hole, with will probably be a circle instead of square, so it looks neat and professional . and get some sort of scoop under the car, and evetualy see about getting the pipe ceramic coated, maybe i can find some sort of coating that isn't supposed to be used to headers so it will be cheaper, cause i know exhaust companys are getting alot of profit on coating headers just because they know its popular, but enough of that. ill keep yall updated with pics and stuff, this should be cool.
- David
1 Post
Breathment, get header spray paint... it works, and it's only like $5 a can.
As for placement of a filter there, be careful, because that sh*t gets wet there real fast. My canister has a hole underneath it, and when it rains that whole area gets wet. Even washing my car does it.
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
Hotrodboba400
12-10-2019 07:07 PM
