do L98's require valve lash adjustment?
ok, i know i should know the answer to this question, but do they?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
- David
yeah, but not periodically like a solid cam does. the L98 is a hydrolic roller so it has zero lash, just like any other hydrolic set up.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: Take
Engine: Your
Transmission: Pick
It should be like that Ronco Rotisserie, "set it and forget it". Thats the whole beauty of hydraulic lifters, once you properly set them, they maintain zero lash on there own.
The only time you would have to re-adjust them is if a rocker nut backed off. If it happens, you need to replace the nut. (its a pinch nut).
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
[This message has been edited by GMTech (edited December 02, 2001).]
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
1988iroc350tpi
08-14-2015 07:52 PM
