cutting braided hose
I got some braided hose for a fuel line, and I think I messed it up. I couldn't get it into the connectors, so I was going to cut a small amount off of the ends to clean them up. I heard somewhere that you should use a hacksaw. I looked around the shop, and only found a sawzall. Needless to say, they aren't the same.
So... what is the right way to cut braided line?
Jeff
'85 Berlinetta, Special Beater Edition
Mods include a 4bolt 350 with 280*, .460 lift cam, Vortec heads, Comp Cams roller tip rockers, Edelbrock TES headers, no other exhaust . Also, rusted parts on all 4 corners, and crumpled fenders, thanks to the previous owner.
Jeff
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I think it is recommended to wrap the line with masking tape where you want to make the cut and then use a hacksaw. The tape will keep the braiding from fraying when you saw, which is what I think is happening to you.
Exactly what Sitting Bull said.......
85 Berlinetta Iroc exterior NOW 454 powered, 4.10 gears, 275/60/15 Hoosier Quicktimes freshly installed th350 3200 stall, shift kit, reworked valvebody, Megashifter, Biondo linelock ..........YES, it's street driven!
check it out at http://www.bsronline.net
Do you leave the tape on when you put it in the connectors? When I tried to put it together, the braided part frayed and wouldn't go in. You were right about what I did, although I did use the masking tape. I think the sawzall was overkill.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A hacksaw with a fine blade works ok, or you can use a rotory tool with a cut-off wheel. Wrap the area around the cut tightly with tape before you cut. Remove the tape after cutting. Any odd individual strands sticking out can be cut with sharp diagonal cutters.
If you're having trouble getting the ends on, put a worm-type hose clamp on about 1/8" or so from the end of the hose and tighten it down until it compresses the braid. Use a twisting motion when pushing the end on and try to get all the strands in. Once it's started you can take the hose clamp off and slide the end the rest of the way on.
Car: 1983 Z28
Transmission: WCT5
As long as it's not the teflon lined stuff a "beverly shear" works slicker than snot.
Unfortunately it's not a common tool in most of our shops . It's like a very big pair of tin snips (in function) that is bench mounted. If anyone does have one of these, try it out. It works GREAT!
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
http://communities.msn.com/clemsprojects
Clem
Engine: 383 Carb
Transmission: 4L60
How did you get that to work? A bench shear would flatten the hose as it cut, flaring the braid and making a hopeless mess.
Car: 1986 Firebird
Engine: 2.8 V6
Aren't the beverly shears throatless? Seems like it wouldn't mash the hose...?
-Tom P (Hot rodded 1986 Firebird 2.8l)
Car: 1983 Z28
Transmission: WCT5
It will flatten it some, but I've had very much success with this method of cutting hoses
now:
since most of us don't have a beverly shear...Wrap it with tape and get a high speed cutoff wheel. It will to a good job too. You might have a few stray strands, but a quick snip with some really good end- or side-cutters will do the trick nicely,
HTH,
Clem
Hotrodboba400
12-10-2019 07:07 PM
