Best way to remove stripped alternator torx bolt?
1 Post
Car: 89 IROC-Z
Engine: 383
So my alternator dies on me last week. (only 12k on a GM alternator, but that's a different problem)
I tried to remove it yesterday but the shorter mounting bolt that's on top is stripped out. I can't even jam a larger torx bit into it to just get it out. What's my best option for getting this thing out? I was thinking of using a dremel to notch the bolt and using a large flathead to remove it. It's in there pretty tight though. Any other ideas that might be better?
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Best way to remove stripped alternator torx bolt?
Welding a hex head bolt on to it is another option.
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
What everyone else has said is the usual routes.
Make sure u use a good penetrating oil like PB blaster or the like.
Heat is another good one for siezed materials in aluminum, however you need to be careful and not melt it down :-)
The easy out style sockets are usually sold as some type of "turbo" socket and basically have swedges in it so u can pound it onto the offending bolt or nut and it will grip as it is pounded on and let u take it off.
Can get them at Sears and the like.
later
Jeremy
later
Jeremy
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
All the above will work, Torx can be a real curse even with decent sockets.
Heat is usually the big shifter of all things corroded, but of course with aluminium, and especially aluminium filled with electrical components, take care. I would be using oxy-acetylene with a very fine tip at work, or mig weld a nut over whats left as mentioned above.
Drillings fine if you have a good eye and sharp bits, and a set of taps to clean up if you have,nt.
1 Post
Car: 89 IROC-Z
Engine: 383
Thanks for the replies. I'm gonna try to find a set of turbo sockets later and if that doesn't work I'm gonna try squaring off the head for an open end...that seems like it would offer the most grip. If all else fails I'll drill it and use an easy out, but it's not really a straight shot.
Car: 88 T/A
What if you just grind the end right off the bolt? Once the alt. is out itll be easy to get the bolt out W/ some visegrips.
evilstuie
01-09-2020 08:29 PM
db057
08-11-2015 10:11 PM
