help me choose a cam! please
ok would this cam fit into a stock 305 TPI
Adv. Duration: 272º/284º
Gross Lift: .454''/.480''
RPM Range: 1500-5800
[This message has been edited by britered86transam (edited November 22, 2001).]
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
The lift is ok, but the duration is kind of big for a 305. With this cam you better have really good heads, manifold, and exhaust system. What have you done to the engine?
nothing yet, gm performance exhaust. headman headers in the mail and flowmaster muffler in 2 weeks.
how about this one:
Low & mid range torque & HP for 305 & 350 w/optional gearing.
Adv. Duration: 254º/264º
Gross Lift: .401''/.423''
Series: 2020
or
Adv. Duration: 266º/272º
Gross Lift: .440''/.454''
RPM Range: 2000-5000
or
Adv. Duration: 260º/272º
Gross Lift: .427''/.454''
RPM Range: 1200-5500
also i was told that a 268 grind would be too much for my 305 and would slow it down, is this true?
sorry for asking to muchm, but i am not very knowledgable when it comes to cams
how about this one:
Series: 2020
or
or
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by britered86transam:
</font>
</font>
It runs great for me. But, with TPI, you're going to have to get larger shorter runners and port the plenum and intake to get it up into the cam's power range. Better valve springs than stock a must, screw-in rocker studs highly recommended, ported heads and larger intake valves as well. If auto tranny, higher stall torque converter.
I wouldn't recommend your first alternative cam (not much of an improvement), the last one might be okay, though. You'll still need to "fix" your TPI to get it up into the cam's range.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 2006 Silverado 1500
Engine: 5.3L
my choice of the cams you have listed is the .427 .454 cam. my choice for your application would be comp cams xtreme with .432 and .453 lift and 206 and 214 duration at .050. i have also ran the .440 lift cam dynamics cam in an 86 LB9 and it worked great, but always is room for improvement.
