What the heck is an OBDI ECM??
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Ok, what is an OBDI ECM?? I don't think my '86 TA has an OBDI ECM because I can't enter "Field Service Mode" by paperclipping A and B on my ALDL box after the engine is running. When I do that my idle just drops about 100 rpms and the SES light stays on solid and don't blink at all. Either I don't have an OBDI ECM... or my car is running so rich that the SES light isn't blinking at all... in which case I think my car would be having some issues and stinkin' like a biiiatch.
1986 Trans AM
355 TPI
4 Wheel Disc Brakes
9 bolt Borg Warner Rear (2.77's....oh joy) :P
6" rods, approx. 9.7:1 Compression, Stock TPI (soon to be ported), 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, 1.52 RR (for now), Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech 53,000 volt coil.
Track times to come.
1986 Trans AM
355 TPI
4 Wheel Disc Brakes
Car: 4
Engine: 6
Transmission: 5
Your car should enter diagnostic mode when you short those pins with the key on and engine off. It should blink the light 3 code 12s, then any other codes it has stored, then 12 3 times, then repeat.
ICON Motorsports
ICON Motorsports
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
</font>
Car: 4
Engine: 6
Transmission: 5
OK, gotcha.
OBD I (Roman numeral 1) is what the first generation of On-Board Diagnostic computers are now called. Nobody called them OBD1 until OBD II was specified by the federal gov't. as being required in whatever year it was, 93 or thereabouts. TPI belongs in that class of things, being the age that it is.
I don't know much about "field service mode" though, I've always used a scanner to check O2 indications when I've needed to deal with such things. Of course, if the O2 sensor is fornicated, then what the computer hears from it and reports either to the scanner or the light doesn't necessarily mean a whole lot; so if that's what's making you run rich, the computer might be hearing from the O2 sensor that it's got the injector duty cycle where it needs to be.
ICON Motorsports
ICON Motorsports
hey, rev the engine when ur doing this, this always makes them run lean. maybe you ARE running really rich, or maybe ur O2 sensor isn't flucuating.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
- David
<font face="Verdana, Arial" size="2">Originally posted by breathment:
</font>
</font>
I think you may be a little confused...the long flash/short flash thing does not indicate how rich or how lean it is..i/e it won't flash longer if it's way, way rich, vs. just a little rich.
Long flash/short flash is indicated at the rich/lean condition (450mv IIRC) of the o2 sensor output.
efiguy
09-27-2015 01:30 PM
