Best Factory Head (with at home mods) to use with 383
Old 11-19-2001, 12:30 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
Well, it turns out I may not be able to go with my original plan to use Vortec heads due to legal constraints. What casting number head should I be looking for. My car is an 86 IROC currently holding the LG4. It will have a 383 (or 355) Extreme Energy 268 cam, headers, Flowmaster Force2 cat back, CCCS carb, Performer carb. I would appreciate all input. I know I can get great aftermarket heads, but they will cost more than what I can spend right now so I will just get what I can for the time being.
Thanks,
Mark
1986 IROC LG4 "Bone Stock" (for now)
Old 11-19-2001, 02:06 PM
Damon's Avatar
I wouldn't reuse the stock 305 heads- they will raise compression too much versus 64 or 76cc 350 heads plus they don't flow worth a damn.
I have 2 sets of 1987 cast iron L-98 350 heads laying around in good condition, ready to bolt on. They came off running motors and are complete with stock springs, valves, etc. and are in good condition. They're nothing special, performance-wise, but I'm only looking for $50 a pair (plus shipping which is another $70 or so).
They are early centerbolt heads that do NOT require self centering rockers, so you could reuse your vavletrain stuff off the 305 with no problems. 64cc chambers, 1.95/1.50 valves. No cracks, never milled, guides good, fresh seals, etc.
SHoot me an email if you're interested.
Old 11-19-2001, 02:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Look for ehe old "double hump" castings with bolt holes, such as 186 casting. They are particularly common on 69 & 70 Impala and similar "land barges", especially station wagons. Almost any 350 4-barrel in those applications and years would have those heads. They are completely compatible with all accessories and other details of 86 and earlier F cars, except for the rearmost exhaust manifold bolt on the pass side.
Casting # 3927186
ICON Motorsports
Old 11-19-2001, 02:17 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
882's have decent flow numbers and respond well to porting according to CHP. Typically 72 or 76cc.
Old 11-19-2001, 02:20 PM
SoCo80p's Avatar
882's are kinds crappy, best are as said (and about the only ones you can use) are the 69-70 camel hump heads, everyone and there mother wants a pair of 69-70's as they are the only ones with assory holes so look to pay 200$ or more for a pair of CORES.
Old 11-19-2001, 09:48 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Check out Mortec.com. There is a complete list of sbc head castings there.
for a flat top 355 cu in. look for a 64 cc head. for a flat top 383 look for a 76 cc head. Either can be home ported for good
street performance. Try to find the '74 and older castings. They are a heavier casting.
Also consider the alumium L-98 Corvette
heads which port up nicely too.
http://www.mortec.com
Why are the vortecs illegal?
Old 11-19-2001, 10:32 PM
MotorCityMuscle's Avatar
882's are not crappy heads. If Im not mistaken, they flow better than the aluminum Corvette L-98 heads, not to mention the iron F-body versions. I believe Vader posted some actual flow numbers a while back and the results were surprising.
Old 11-20-2001, 08:55 AM
Car: 1986 IROC
<font face="Verdana, Arial" size="2">Originally posted by F-BIRD'88:
</font>
The Vortecs don't have EGR provisions that I know of, at least the intakes that I have seen for them don't. So if I have to move ( I am military) to a state where there is a visual inspection I wouldn't pass. This is my assumption, I you could tell me otherwise I will go ahead with the Vortec's. Thanks for your help!
Mark
Old 11-20-2001, 12:16 PM
Damon's Avatar
Technically that's true but you can get an external EGR kit to plumb exhaust into the cross-over passage in the intake and keep the EGR system functional. You'll need one of Edelbrock's intake manfiold's (I believe it's Edlebrock) to make this work.
Even if you DON'T use the external kit there isn't anyone who's gonna know the EGR isn't fuctional just by looking at it from the outside. Just leave it there and functioning, but even when the valve opens nothing will flow through it. No biggie in my book.
Old 11-20-2001, 01:09 PM
Car: 1986 IROC
I found an EGR adapter at Summit that says: "EGR Adapter, Vortec 87-95 required to route exhaust to the EGR valve", Is this what I am looking for? It doesn't say if it 50 state legal or not. Now, correct me if I am wrong, I can use this with the Vortec head and intake manifold and still have a funtioning EGR system and that should be legal. Is this true?
Mark
Old 11-20-2001, 01:31 PM
E-Z Rollin's Avatar
882 heads may flow decent[don't have the numbers]but they had double heat riser passage and run hot,they are prone to cracking so examine them carefully. A good production gm head [heavy casting]that would be worth rebuilding if needed is 3998993 from 1971 up came on 350/400 sbc and would have 74/76 chambers to keep the compression streetable.The early double hump heads would raise the compression to high with flat tops and most of them have had numerous valve jobs already.
Old 11-20-2001, 02:37 PM
F-BIRD'88's Avatar
Check out GM performance parts intake manifold PN#12496820 It is a "performer" like intake for vortec heads that has a EGR boss and dual pattern carb pad. You'd need an EGR valve and some plumbing to the exhaust manifold to hook up a functional EGR system. But would be functionaly equivelent
to the stock EGR. Should be "smog legal" in all states.
Old 11-21-2001, 11:31 AM
Damon's Avatar
I think you're on the right path. I have not done it myself, but what you are finding agrees with what I've read/been told.
Nervous2
LSX and LTX Parts
03-10-2016 09:49 PM
Reddeath210
10-06-2015 08:20 AM
86IROC112
08-21-2015 07:20 PM
86White_T/A305
08-17-2015 12:16 AM
fonzie85
08-13-2015 11:50 AM
Quick Reply: Best Factory Head (with at home mods) to use with 383
