emissions control! new intake/carb
Car: 1984 Camaro Z28
Engine: LG4
Transmission: th-700
just put a new carb and intake on today (holly street dom and holly 600) the vacuum hoses are driving me nuts. i was careful to pay attention to where all the hoses went but the new carb and intake look totally different. question is, can i remove all of the emissions control cr@p? if so how can i tell what vacuum lines are what?
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Only way your going to do it is if you dont have any emissions testing, Even with all emissions equipment some of these cars have trouble passing the test.
Engine: LG4
problem is, some of the stuff wont fit back on due to the manifold carb set up. there is some sort of saucer looking sensor that was mounted off to the side of me carb that now will not fit. the manifold came with a plate to covet the holes though. this part is pretty big, looks important for the system, you know what i mean?
Engine: LG4
just had my car inspected this month, can anyone tell me what i can remove without risking any loss of power? willing to take the chance for next inspection.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Taking all or any of the emissions stuff of will give HP gains and weight savings.
And the "saucer" does sound like your talking about the EGR. Part of emissions control, Most likely will need it to pass emissions.
Car: '91 bird '87 Z28 '86 T/A
Engine: LO3 LG4(ls1 in works) 350
Transmission: 700R in all
Axle/Gears: wimpy 10 bolts
if you really want to take them off, go right ahead. just be sure you have some way of passing inspection or plan on driving very little with some exempt plates. just my
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Listen to Kintaro Oe. He's all study, study, study, but it's very educational. Too bad he never graduated from law school though.
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by Apeiron
You never know when you might need that 5 lbs and 2 HP.
Engine: LG4
i plan to replace it later when i have the money. its just when i was taken it apart alot of the hoses and stuff were dry rotted. im not worried about losing horsepower. im just worried about putting it all back together . i need to get the car back on the road for now. just had an inspection done this month too.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Re: emissions control! new intake/carb
Originally posted by 84camaroZ
just put a new carb ... on today (... holly 600) ...
There are vacuum diagrams on the FAQ forum. You should also have one on your hood or radiator support. You're basically turning this into a non-emissions vehicle, so hook up what you need to make it run.
That should eventually include the vacuum advance for the distributor you don't yet have.
Engine: LG4
Re: Re: emissions control! new intake/carb
sorry bro, you keep losing me.
Engine: 383 Carb
Transmission: 4L60
If you put on a non-computer carb, you need a non-computer distributor as well. Computer control is an all-or-nothing thing. Either you leave all the computerized parts on, or you replace every function of the computer.
Hotrodboba400
12-10-2019 07:07 PM
