Firing Order
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
Firing Order
I know there's a way to figure out the firing order of a motor, besides looking on the intake, and getting a manual for the car. Actually, what I need to know is what plug goes on which plug on the distributor, from which cylinder. It's a 1973 Buick 455 motor, and it doesn't have the original intake. Some one please help!
2.8 Liter V6
No Current Mods
2.8 Liter V6
No Current Mods
uhm... why would the intake change the fireing order of the plugs? Just go to buick and ask them.. I'm sure they would have records on there computer or something
~1985 Camaro Z28~
V8,305,700R4,K&N Edlebrock Air Filter,& MSD 8.5MM Super conductor Wires,
~1985 Camaro Z28~
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by FAST85Z28:
uhm... why would the intake change the fireing order of the plugs?</font>
Car: 4
Engine: 6
Transmission: 5
Buick uses the same firing order as other GM V8s... 18436572.... I don't recall offhand which way the distributor turns though
get a chilton's
ICON Motorsports
get a chilton's
ICON Motorsports
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Firing order is 18436572. #1 on the distributor can be anywhere you want it depending on how the distributor was installed and as long as all the wires will reach. The buick puts the #1 wire at the right front of the distributor across from the #2 cylinder and the distributor rotates clockwise.
#1 cylinder is the one that is ahead the most. Like the Chev engine, buick has it on the left bank (driver side).
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
