compression ratio and altitude
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
On summits webpage, they mentioned a calculation to find your "correct" static compression ratio, based on your altitude. It's not quite complete (errors), so I was hoping someone else had heard of this? Should I be building my motor for higher compression since i'm at 4000' ?
I know about all the factors in reference to desired compression ratio etc, but i'd never heard of altitude coming into play when finding your static compression ratio, in order to pick a cam.
or would it be better to just give it more ignition timing? (which can easily be changed if I moved to sea level), would it do the same thing?
1 Post
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Re: compression ratio and altitude
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Your dynamic compression ratio will differ. But not the static compression because of its definition. Static compression is just the ratio of max volume divided by min volume.
Car: 1982 Trans-Am
ok ok, fair enough then, dynamic compression ratio, does anyone know how that is effected?
or can answer my other questions?
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Finally someone else said it!!!
Dynamic compression cannot be measured by some computer program that some guy made based on the IVO, stroke, static compression, etc.!!!
By definition, dynamic describes something that changes.
Anyway, it would only make sense that the dynamic compression would change due to altitude. The higher up you go the less dense the air would become, therefore lowering the dynamic compression. Vise-versa with going down.
Damon
09-26-2015 04:29 PM
83 Crossfire TA
09-08-2015 12:06 PM
