86 camaro timing
Car: 84 camaro z28
Engine: '89 L98 converted to CC Quadrajet
Transmission: '89 700-R4
86 camaro timing
hi there, well i got a 86 camaro sports coupe v8, and i've been reading about having to disconnect something when fixing the timing on the car. can somebody please let me know where and what i need to disconnect, i looked on the passenger side where the blower is and i didn't find anything to there. if you all could help, right now the car is having trouble starting.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I believe its all in the tech articles on the TGO main page. or try the lovely search feature, i know it gets asked quite often.
Car: 84 camaro z28
eveyone seems to talk about the est on the tpi or tbi cars. what do i have to disconnect on an 86 with an lg4? is there an est and where would it be located? or do i just disconnect the esc and where is that located on an 86 lg4 ccc carb? some other post had mentioned that the carbed cars might not have an est. any help would be greatly apprectiated.
Car: 1987 Camaro IROC-Z
Engine: LB9
as i recall its near the blower box on the firewall, tan wire with a plug that connects it to itself, disconnect that plug. set your timing, reconnect it. yes its normal for your SES light to be on then,
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The CC q-jet connector is a flat 4-wire connector that comes out the bottom of the distributor body. It goes to the harness behind the engine on the firewall. It's typically difficult to locate unless you get your face down in there and dig around a little.
Linson
08-21-2015 02:12 PM
