Pre Bent Fuel Lines
Those are probably a dealer-only item. I know that's the case with transmission and oil cooler lines...
And don't frown, they're not really that expensive. If you compare the price of the same steel lines, fittings, flare tool, and the bender, the dealer sets are actually cheaper.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Later,
Vader
Car: 91 RS
[QUOTE]Originally posted by Vader
[B]Those are probably a dealer-only item. I know that's the case with transmission and oil cooler lines...
Later,
Vader
[b
I found this doing a search and I have thought of this but I cannot seem to find the GM part numbers.
Later,
Vader
[b
theshackle
03-05-2017 06:37 PM
ambainb
04-25-2016 09:21 PM
AkDrifted
08-17-2015 07:45 PM
