5.7 vs. 6.0 Rods?
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Actually, price for 5.7 vs 6.0 rods and pistons are often the same.
But other things comeinto play.
Start with this and then ask questions after you get caught up.
https://www.thirdgen.org/messgboard/...ML/015032.html
a 6.0 rod will be better as it will not put as much of a strain on the piston at the end of rotation as the 5.7, but really there not alot of jerking with the 5.7 eather, this is more of an issue with the 400's as they have a 5.55 rod and the 6.0 helps out ALOT, but on a 350 the 5.7 (stock) is just fine, also with a 6.0 on a 350 sometimes you have to machine the block to accept them.
KO1
16
10-15-2015 05:00 PM
LT1Formula
10-08-2015 08:34 PM
skinny z
10-05-2015 06:23 PM
