350 build output
Car: 90 Iroc-Z
Engine: carb'd 350
Transmission: built 700r4/3000 stall
350 build output
Hey, I was just wondering if anyone with DD2000 or something similar could give me an idea on what the engine im almost done building should make. Heres the specs on it:
4.000" bore, and 3.48" stroke
Engine has an SCR of 10.7:1, and a DCR of 8.2:1
Engine will have a port matched victor Jr. and a holley 650DP
Cam is a lunati voodoo 284/292 (241/249) .525/.546 lift, 110LSA, 106ICL
Im putting 1.6 ratio rockers on, so cam lift will be .560/.582
The heads flow:
Lift Int Exh
.100 67.3 40.3
.200 127.2 76.2
.300 178.1 106.7
.400 208.2 124.7
.500 220.4 132.0
.600 226.1 135.4
The heads flow:
Lift Int Exh
.100 67.3 40.3
.200 127.2 76.2
.300 178.1 106.7
.400 208.2 124.7
.500 220.4 132.0
.600 226.1 135.4
Car: 90 Iroc-Z
Engine: carb'd 350
TTT, im open to guesses as well, also, you think a 650cfm is big enough, or do you think i should get a proform main body as well?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
650 is good close to 6500 RPMs. Since you will have a single plane intake, overcarburating is more of an issue.
But, the Proform mainbody isn't likely to hurt you.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
which heads?
edit: ported 462s, ok. What is combustion chamber size?
Car: 90 Iroc-Z
Engine: carb'd 350
Ported 462s, going to mill to 58cc, std deck height (around .030 IIRC), -6cc flattops, shim head gaskets (.018 thick, 4.100 bore). DCR calc gives me a SCR of 10.67:1, and a DCR of 8.29:1
Oh yea, my sig is outdated, the only thing that is right on that list is the heads, and the block.
Car: Cobra Kit Car
Engine: 350 HSR
Transmission: TKO 600
Axle/Gears: 3.31
I have done a quick DD2000 with your information.
If you can find the CAM information with the seat-to-seat instead of @0.050 lift it would be better. (According to DD2000)
I have used the valve size of 2.02 and 1.6.
I have used the piston to deck distance of 0.025 with a normal deck height of 9.025
So you will have a total volume above this piston (include the -6cc of 10.94 cc and that makes a compression of 10.84 (static)
The results are:
273 HP @ 4000 rpm
396 Ft-lb @ 3000 rpm
My first impression is that you need a different CAM but I am not an expert.
I will try to post the "pdf" with all the information from DD2000 and please correct me if you find some discrepancies.
http://www.donostia.demon.nl/Ported462s.pdf
Edit:
I forgot to ask:
Do you have Hydraulic Rollers? This make a big difference.
From 273 HP to 309 HP
Regards,
Cobra289
The results are:
273 HP @ 4000 rpm
Edit:
I forgot to ask:
Regards,
Cobra289
Car: Cobra Kit Car
Engine: 350 HSR
Axle/Gears: 3.31
I have put my CAM in your combo (I am also building a new engine) based on a partial engine.
The cam is an Isky 211257/265 wit a duration of 209/217 @ 0.050 this will give you a different performance.
HP = 370 @ 5000 rpm
TQ = 445 @ 4000 rpm with a healthy 399 FT-lb at 2000 rpm
The left with 1.6 rokers will be 0.496/0.517
As you see your heads will perform better with less CAM.
But I told you I am not an expert.
Perhaps some one can jup in and hep us to verify those figures.
HP = 370 @ 5000 rpm
The exhaust port flow is very weak for a "ported head"
Something is wrong. Were the ports tested with a "pipe"?
should be 170 to 200cfm. Makes a difference.
Once you get that sorted out it has 400-430hp potential.
Don;t need DDyno to know that.
Car: 90 Iroc-Z
Engine: carb'd 350
Yeah, im 99% sure they were flowed without a pipe, which i forgot makes a big difference. Yeah, the intake flow #s say it could make up to 464hp, but i was just wondering what DD2000 say.
Car: Cobra Kit Car
Engine: 350 HSR
Axle/Gears: 3.31
Yes I agree with the previous comments the flow values give for the heads are not proper.
If you check the percentage is never higher than 60% between the exhaust and the inlet.
I have found for you a site that gives the flow of this heads but standard (no porting) and small valves.
http://users.erols.com/srweiss/tablehdc.htm#Chevy
I have run those values at the DD2000 and here you have the results.
382 HP and 382 Ft-lb of torque.
Here is the result file:
http://www.donostia.demon.nl/REV-Ported462s.pdf
Regards,
Cobra289
Regards,
Cobra289
Car: 90 Iroc-Z
Engine: carb'd 350
Cool, thanks a lot. So I should have a pretty stout motor, since my heads flow quite a bit better than the ones you entered. Cant wait until its done.
Eric-86sc
08-24-2015 09:01 PM
