new coolant temp. gauge problem
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
thanks for everyone who helped me before, but just when things seemed fine for a while, this problem arose not too much later after. this time the gauge pegs when i start the car, and if i really give the cluster a good banging the needle will drop to the appropriate reading. for some reason the check engine soon light will come on giving me a code of 15. why is it that the gauge will peg upon starting the car, and go back to reading normally when i whack it? i still think that possibly i forgot to replace a ground after installing the manifold. can anyone shine some light on this for me?
1987 LG4 Camaro z28
Performance
KN airfilter, flowmaster 80 series and catco high flow converter, 180* thermostat, edelbrock performer intake, msd blaster coil
System
Panasonic CQ-DF200U deck, fosgate speakers (hpc1369, frc2246), fosgate 400a4 amp
1987 LG4 Camaro z28
Performance
System
Car: 4
Engine: 6
Transmission: 5
The gauge is designed to peg during startup. It's done by the same wiring that makes a temp idiot light come on when the key is in Start.
It is not normal for it to peg. Pop your cluster bezel off (about 10 or 12 little Torx screws) and then the window (about 6 7mm ones) and see if the gauge pointer is bent or something to where it rides up over the end-scale stop instead of just coming to rest against it. You might be able to bend it, or it might have some foreign matter making it sticky.
Code 15 is the CTS not showing a sufficiently high coolant temp (130° or some such) within like 10 minutes of running. Ususally it's caused by a broken wire or bad connection, which can include the ground lug up there by the water outlet.
ICON Motorsports
ICON Motorsports
Ghettobird52
07-05-2024 11:18 PM
