I need to know what head castings these are...
ive got a local guy that is wanting to sell a set of heads. he says that theyre L98 heads but i cant find the casting number in my book. the casting is 14102193. the build date is F097 which i believe is june 7,1987. can anyone help.
jp taylor
jp taylor
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The casting number for iron L98 heads is 14101083, so those arent it.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Yes 8Mike9 is right.
I have those same heads. Although mine are #191s. They are 76cc chambers, 1.94"int/1.5"ex. They are also the "light" castings. This means that they aren't very strong under high comp because they have 'mounting tabs' (for lack of a better word) on the perimeter. The head bolts are held on by VERY SMALL, THIN metal tabs.
Any comp ratio that is higher than 9:1, which mainly results in higher heat on the casting, will heat those tabs so they can crack easier. Then there's the internal pressure forcing the heads "up".
I would pass on those. I was debating on using the ones I have on my 355 build up to save a little dough. But after all is said and done (they need a rebuild) it would be better for me to buy aftermarket heads.
AJ
AJ
92projectcamaro
01-18-2016 08:00 AM
