hot start
hot start
i searched the archives to find info on ts common problem, but no one says how to fix it. so could someone tell me what to do to fix this hot start problem
89 Rs camaro
305 tbi
3in flowmaster muffler
manderal bent pipe
no cat
ELECTRONICS
viper alarm
pioneer 4-way 6x9's
15' orion sub in a bandpass box
150x1 kenwood amp
140watt aiwa head unit
89 Rs camaro
305 tbi
manderal bent pipe
no cat
ELECTRONICS
viper alarm
pioneer 4-way 6x9's
150x1 kenwood amp
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
If it makes you feel better, I have that problem too
Cold Start = Vrooooom
Hot start = Takes 2-3 turns of the key to start her up.
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC In Readers Rides
My IROC
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC
i think it has something to do with the fact that during most cold starts, we have extra fuel being added, cause the engine is cold, 87+ (?) cars have the cold start injector, while 89+ have main injector enrichment, so this is why I think cold starts are better then warm starts. also, might wanna try replacing Coolent temp and manifold air temp sensor (we have one right?)
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
- David
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Is the motor turning over but not starting? Or is it not turning over at all? Or turning slowly when its hot?
90 IROC
SuperRamed 406
Trickflow 23* heads
90 IROC
SuperRamed 406
Trickflow 23* heads
Car: 1988 IROC-Z
Engine: 427 SBC
With mine it turns over fast whether its h ot or cold. Just starts 6 times better when Cold.
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
if it turns over slow when hot your starter is could be getting heat soaked, therefore making it get weak. check to make sure your battery cables are good and clean. make sure you have a good strong ground. also when an engine is really not things expand and clearances are tighter in the engine, and on a warm engine there is oil on the rings causing compression to be a little higher.
if it cranks over but wont start when hot, check to see if your fuel mixture is off. lean or rich, and retard your timing a bit.
86 IROC
43,000 miles
305/700R4/3.23 gears
maroon, gold stickers, black interior, T-Tops.
current mods.
shift kit
headers
cat back exhaust
mods planned for this winter
cam
3.73 gears
subframe connecters
[This message has been edited by 1MeanZ (edited October 19, 2001).]
86 IROC
43,000 miles
current mods.
shift kit
headers
cat back exhaust
cam
3.73 gears
subframe connecters
theshackle
03-05-2017 06:37 PM
db057
08-11-2015 10:11 PM
