Rocker Arms for AFR Heads
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
Hello to all. I am sorry if this is a stupid question. I have done searches and have not found my answer. I have AFR 180cc Heads. I thought that I could just reuse my old stock stamped GM rocker Arms. I have been measuring the pushrod length and I noticed that the rocker arms don't seem to be compatible with the springs. The rocker arms seem to rub on the springs. I need to know, are either the self aligning or non-self aligning rocker arms are compatible with 1.450 Springs.
Yeah I'm a little dumb when it comes to engine specs, But I can fix most problems with our cars by listening to them, well, most of the time.
Soon to be OneBadZ4U again!!!!!
Sorry bro, that didn't answer my question. I know the diff between self and non. Just want to know if stock may work. I looked in summit paper catalog, no good info. I know what I could buy, but I don't want to buy anything, yet. Thanks Bro.
Re: Rocker Arms for AFR Heads
Originally posted by OneBadZ4U
I need to know, are either the self aligning or non-self aligning rocker arms compatible with 1.450 Springs.
I didn't mean to imply what everybody has already concluded from my question. My bad.
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
they should be, with the correct geometry, sometimes you have to remove a little metal from the bottom of roller rockers for clearance. there's a very good chance you ought to go aftermarket for your rockers
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
You should consider an aftermarket set even if you can make the stockers work. If you care, I've got a set of the wide body harlan sharps with centerbolt valve covers the I just had to modify to make them fit. I like the idea of a bit beefier rocker. I've also use the Crane Gold rockers, and Scorpion wide and narrow bodies on AFR heads. Always have used non SA and guideplates.
well what I was saying is the will tell you what springs they clear. which is what you asked.
here are aftermarket stamped rockers http://store.summitracing.com/defaul...h.asp&x=24&y=8
the roller rockers are listed the same way
well, looks like the page did not save but, you get the idea if you go through a few pages most say the max spring size
ambainb
04-25-2016 09:21 PM
