Forged piston question
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I'm looking to get some forged pistons for my 305 and was wondering if there is much of a difference in quality between the different manufacturers? I was wanting TRW but everywhere is out and federal mogul say the wait will be 7 weeks.
The other manufacturers I can think of are Keith Black, Speed Pro, JE and Trick Flow.
What do you guys think?
Oh, and if anyone can find someone with the TRWs in stock I may feel obliged to sending you a little something.
Thanks for the time.
Robert
Robert
What CR? Pin type? Ring position? Do you have a TRW part number?
Later,
Vader
Justice and Freedom will Prevail
Adobe Acrobat Reader
Later,
Vader
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends what you want the engine for. Any choice you make will require having the engine balanced. TRW (SpeedPro) pistons are heavy. JE are race pistons and you're going to pay big bucks for them. They're very light and have very deep valve reliefs for high lift cams.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
Car: 87 IROC
Engine: modded LB9
Vader,
The part number that I have is from summit racing and it is: TRW-L2486F30.
The reason behind fitting forged ones was because of a supercharger next year.
Thanks for the help
Robert
Thanks for the help
Robert
if you're running a power adder i'd run forged. trw and most lower priced forged pistons are heavy. the more expensive pistons are light, very light usually, and often made for racing only. i'd stay away from hyper pistons in a power adder because of the heat transfer is much greater and you have to watch the ring end gap.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
So, what would be the draw backs of forged pistons that are light and made "for racing only", other than price? will the cheap "heavy" ones last longer in a engine(theoretically)or will they have more negatives like more strain on the rest of the engine and/or poor tolerances in manufacture leading to premature failure. I'm just wondering anyways, it's not really important right now to me. If I wanted to make/buy a 383 to make ~500hp N/A(if that's possible)and somewhat street worthy,also with perhaps a 150 shot occasionally. Would that engine be able to last say 40,000 miles=(2-3 yrs driving and probably ~50+ runs at the strip) 1 more thing. Anyone know how much a LT1 manifold can support for horsepower N/A(in a 383 or 350)?
Car: 87 IROC L98
Heavier pistons just means there's more recipricating weight in the engine. I still use TRW pistons in my race car mainly because they were cheaper. Some JE or SRP pistons would be my next choice.
If you buy heavy or light pistons, you still need to get everything balanced. It just with the lighter pistons, the engine isn't trying to spin as much weight. A 3 pound piston trying to pull the con rod off the crank at TDC creates more forces than a 2 pound piston.
84z96L31vortec
08-20-2017 12:16 AM
LT1Formula
08-20-2015 09:36 PM
84z96L31vortec
08-10-2015 08:27 PM
