350 rebuild
350 rebuild
well my 305 is pretty much dead and so i am going to be rebuilding a 350 soon. my question isnt really about the rebuild though. mostly i want some opinions on things like cam, intake manifold. i already know im going vortec heads, so from there what should i get? i want this baby to be streetable, and it will be backed by an 4spd auto. thanks.
Car: 4
Engine: 6
Transmission: 5
The combo that seems to max those heads out is a Comp XE268H, I'd strongly suggest some better rockers with it than stamped sheet metal ones like Comp 1412s; Performer RPM; Holley 750; 1¾" headers like SLP. People get in excess of 425 HP with this combo.
A converter will help dramatically, especially if your gears are less than 3.42s. 2800 stall and 3.73s would be about the best for the street; you'll definitely propel yourself into a wheel spin issue with that setup. That should take the car into the 12s easily.
ICON Motorsports
ICON Motorsports
Well that seems very nice, but how bout something a little more mild? Id like 320-350 horses or something around there, and torque similar to that, just something mild, sorry to be so picky.
oh yeah, will those numbers (320-350) be possible with my 305's QJet? I only ask to keep things a little simpler, and also if I can, what intake manifold would I want then?
I have a 350 with vortecs and XE268. I first used the stock converter until mine was built for my car. The 268 didn't like the tight converter very much. I use 1.6 rr's and 3.73's. After I got my 3000 stall it made a huge difference.
That being the case you should check out the XE262. Just a little more mild and probably will like the converter better. That is if you will use the stock converter.
I also have another suggestion. I had a goodwrench crate motor that I put a comp cams High Energy 268 in. This cam has .460 lift on intake and exhaust. The motor only had 8.5 compression. I put this in my 83 Z-28 and used 1 5/8 headers and performer RPM intake. I used a Edelbrock 600. The gears were 3.23's. It ran low 14's which is what my 94 LT-1 Z-28 runs. That was a great setup for a daily driver that was decently quick. I dusted lots of mustangs with that motor. If you want more info on this setup feel free to e-mail me.
well i decided on GMPP for my manifold, the aluminum designed for vortech heads. will i be able to put an open element on that (im gunna put an xstream top on it, to be fed by my LU5 hood), and what cam should i be looking at to match these?
1 Post
Car: 99 Formula
Axle/Gears: 342
If you want to keep your Q-Jet, make sure you get a CC distributor as well.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
The Comp Cams Magnum roller-tip rockers are great. I believe that was what RB83L69 was talking about, but I don't remember the PN. Just make sure you get the self-centering rockers for '87 and later engines. The milder cam mentioned earlier should do great, also.
Jeff
'85 Berlinetta, Special Beater Edition
Mods include a 4bolt 350 with 280*, .460 lift cam, Vortec heads, Comp Cams roller tip rockers, Edelbrock TES headers, no other exhaust . Also, rusted parts on all 4 corners, and crumpled fenders, thanks to the previous owner.
Jeff
Magman
09-13-2015 08:43 AM
Eric-86sc
08-24-2015 09:01 PM
