cylinder head ID
Old 10-09-2001, 04:34 PM
johns84bird's Avatar
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
cylinder head ID
Hey guys,
I am trying to find out what these iron heads are worth and if they are a good iron head to port and get some decent power out of. They came off my GM crate motor and were brand new when I got the motor. They have about 40,000 mi on them. The casting number is 83417369, and they have 72cc combustion chambers, 1.94"/1.60" valves. I looked around on mortec.com and some other places, as well as searching the message boards. I can't seem to find any info on them (i guess cause they're pretty new).
John
  • 84 Firebird w/ T/A gfx
  • 350 4bbl (LM1)
  • Automatic
  • Non-leaking T-Tops (new rubber all around)
  • Working headlights (new parts)
Mods: 14" K&N open element, 160* stat, ram-air hood, Accel cap & rotor, MSD Super Conductor Wires, 24mm solid rear & 36mm hollow front sway bar w/ PST polygraphite bushings & endlinks, Spohn SFCs, WS6 springs, SLP 1 3/4" Jet-hot coated headers, Hooker 3" cat-back, Catco high-flow cat, Comp Cams High Energy 268 cam, AFR 190 heads, Weiand Action+ intake, Comp Pro Magnum 1.6:1 Steel Roller Rockers, Moroso Oil Pan with trap doors, windage tray and crankshaft scraper, poly graphite motor mounts, K&N oil filter and Mobil 1 synthetic.
http://www.homepagez.com/350thirdgen/
Old 06-27-2003, 05:15 PM
James Montigny's Avatar
Anyone ever figure this out? I've found heads with that number as well. I'd like to get some use out of em.
Old 06-27-2003, 10:06 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
the first 8 is probably a 3.. 33417369...90-up...350..........Gen.I Goodwrench crate motor, Hecho en Mexico", 76cc... as far as i know they are basically the same thing as some 70's smogger heads..
Cornholio7979
09-20-2018 02:31 AM
Chuck84TA
07-15-2016 09:05 PM
Bubbajones_ya
08-31-2015 12:02 PM
NinjaNife
08-23-2015 11:49 AM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
Quick Reply: cylinder head ID
