removing the throttle body, and plenum
To remove these things, do i just unbolt it and take it off, or are there snesors and all this other stuff that can get messed up big time??? i want to polish the plenum and maybe the throttle body and whatever else i can.
Thanks for your help.
1992 z28 25th Anniversary
All black w/ z28 wing
Flowmaster Exhaust
350 TPI
Flowmaster Exhaust
350 TPI
Car: 91 camaro
Engine: 383
Taking that stuff off is pretty self-explanatory and you really can't mess anything up. The only thing you need to be careful of is with the vacuum lines attached to the TB. Make sure you don't break one or forget to unplug one, as they are pretty brittle after 10 years of use. Also don't forget to unplug the IAT sensor on the underside of the plenum.
91 Z28
Come see The Vicious...
91 Z28
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
If you are going to take the plenum and runners off, you might as well port the plenum and pickup some power. There is a technical article on this site that tells you all about porting the plenum and my website has a shot of the front of the plenum with the TB off after porting it. You might want to upgrade the runners while they are off as well. SLP siamesed runners are going for pretty cheap. Heck, you almost have the heads off at that point... you can pick up some AFRs or Trick Flows and.. and........ ahhhh.. nevermind.
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
1987 GTA L98 MD8
My GTA
Heh, thanks for your help guys. I am trying to gather information by this winter, cause my car will never see snow During this time i am gona garage it and clean up the engine, i dont think i am gonna buy anyhting new for it now, need to make some money first.
Flowmaster Exhaust
350 TPI
Flowmaster Exhaust
350 TPI
Terrell351
06-13-2021 01:13 PM
mdtoren
08-16-2015 05:45 PM
