head modding to increase CR
Old 08-09-2005 | 02:37 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
Is is possible to have my heads milled to increase the compression ratio? If so, what would I need to increase it by .5 to make 10:1?
Old 08-09-2005 | 02:40 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Yes.
How much depends upon crown to deck height, head gasket compressed volume, and chamber volume.
Old 08-09-2005 | 02:47 PM
Car: 88 Camaro
Engine: 310 LG4
what do I need to do to figure this out? I'm using standard gasket size as far as i know. The heads are stock 416 heads with bigger valves.
Old 08-09-2005 | 04:44 PM
five7kid's Avatar
Engine: LS1/LQ4
Measure the distance from the piston crown to the block deck at TDC.
CC the chambers.
Pick a head gasket that gets you .040" from crown to head. The gasket manufacturer should be able to provide compressed volume.
Mill the heads to get the CC's that give you the CR you want.
Old 08-09-2005 | 05:03 PM
Car: 88 Camaro
Engine: 310 LG4
lol, no guessing then eh? Ok thnx for the info i'll try to get this put together. How do I CC the heads? The heads are stock except the valves, isnt it like 58cc?
Old 08-09-2005 | 08:33 PM
five7kid's Avatar
Engine: LS1/LQ4
Like 58cc. Or 56cc. Or 64cc.
Manufacturing variation, don't ya know.
Old 08-09-2005 | 11:16 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
CC the chambers.
Why .040"? A thinner gasket will effectively increase the CR (in addition to milling the heads) and will also help the quench properties.
Old 08-09-2005 | 11:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Any tighter than .040 and you risk the piston kissing the head.
Notice he's talking about piston-to-head clearance, not gasket thickness.
Old 08-10-2005 | 12:32 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If you installed larger than stock valves in your 416 heads the chamber is now different than stock. Usually the chamber wall has to be clearanced some to get the valve in.
So the chamber is now larger then stock. (58cc)
The only way to determine the size of the chambers on your modded heads is to cc them. ( its' not hard to do)
You can raise the compression ratio of your motor from what ever it is at now to about .5 a cr higher by just changing the typical .040" replacement head gasket for a thin .015" steel shim head gasket. All that is required is a clean straight block decks and head decks. The pistons must be a minimum of .018" below the top of the block deck @TDC. This clearance combined with the .015" gasket thickness would be .033" total. Thats about as tight as you'd want to run it. Most stock blocks that have not been decked have a .025 to .045" deck clearance.
The only way to accurately determine your exact cr is to measure all the variables and calculate.
You can shave your 416 heads about .060" down to the intake valve seat. If you have 2.02's you cannot shave the heads as much as if you have 1.94's. (smaller seats)
I have reduced the chamber size of modded big valve 416 heads to 52cc's by shaveing them. But they were max shaved right down to the intake valve seat and spark plug boss. Because of the location of the spark plug near the deck theses heads do not lend themselves to angle milling.
But like I said the only way to determine how much to shave your heads is to accuratly determine the exact cr you have now.
Old 08-10-2005 | 12:37 AM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
aftermarket heads will probly ebe cheaper or high comp pistioons
Old 08-10-2005 | 12:45 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
It doesn't cost much to have heads milled, less than $100. I think milling my LT1 heads cost $80, but i can't really remember, i'd have to find the receipt.
Old 08-10-2005 | 12:57 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Around here milling is about $30 CDN a head. Milling, valve grinding and assembly is $100 a head.
customblackbird
08-15-2021 11:16 PM
evilstuie
02-28-2016 04:33 PM
haps
Interior Parts Wanted
09-08-2015 11:15 AM
bamaboy0323
09-03-2015 07:07 AM
forstral
08-19-2015 04:20 PM
