Which Driven Gear Color Do I Want??
Car: 89 IROC-Z
Engine: 383
Well seeing as how I broke my original one I figure I should get the correct one for my new gears anyway. I originally had 2.73's I think and now I have 3.42's. Does anyone know what color the gear is that I now need?
Riccioli Performance Motorworks
--RPM Racing--
Getting there.....383 with Super Ram, Bosch 24# SVO's, MSD, Edelbrock 58 mm TB, 700R4 tranny, Eibach springs, Koni 12 way adjustable shocks and struts, and more!! Now let's pray it runs when it's all back together!!!!
--RPM Racing--
Car: 89 Irocz
Axle/Gears: 342
Hey do a search on the tranny board, I did almost the same change you did but I had a 2.77 to a 3.42 sorry I don't remember the combo but they have on there.
Car: 89 IROC-Z
Engine: 383
It's an 89 IROC and I'm going to be running something like 275/40/17's.
--RPM Racing--
--RPM Racing--
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Part# 8642620, Grey drive gear (15 tooth)
Part# 25513048, Yellow driven gear (41 tooth)
That will work acceptably with 275/40/R17 or 245/50/R16 tires as both are ~ 26 inches tall.
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
1987 GTA L98 MD8
My GTA
Guest
Posts: n/a
The 1st is the drive gear (mounted on the output shaft). The 2nd is the driven gear (the one that connects to the speedo cable). Each drive gear will work with a certain range of driven gears. They must be matched. You also may need a different housing, I believe there are 2, one for 41 up, one for 40 and below.
You need to pull your driven gear out so you can count the teeth on it and see what color drive gear is in the trans. Then you can figure what combination of gears and housing you will need.
Unfortunately it's not always a simple matter of swapping the driven gear.
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
?Flowmaster 80 Series Muffler
?83 Trans Am 15x7 Turbo Fin Wheels
?B.F.Goodrich Radial T/A 225/60-15
?Chevy 2.8L Heddman Headers (Going on soon)
Aol instant messenger: FIREAM
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828
<font face="Verdana, Arial" size="2">Originally posted by Matt87GTA:
</font>
</font>
1987 GTA L98 MD8
My GTA
LT1Formula
08-20-2015 09:36 PM
