heads #
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
heads #
just want to see if these are the stock heads that came with the motor the # i found was 333882 there was another # that was i think e305 and it had GM 18 on one head and GM 17 on the other thanls
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Those are lightweight (crack prone) 70's smog heads that came on 350's and some 400's. The feature 75-76cc chambers. The are not very good for performance because of this.
What motor are they on, not your 305 i hope?
Car: 1987 iroc z
no they came off the 75 350 i got just wanted to make shure they were stock heads would it be ok to run 10.3 compression with those heads till i get some new ones.
Car: 1987 iroc z
how about somewhere in the 9 range just want to get a little more power and a bigger cam and i know the 8.1 compression aint going to cut it.
Car: 82 Z28
Transmission: TH350
How do you plan on bumping the compression up. The only way really is new pistons. Or tons of head milling.
9.0-9.3 compression should be fine on pump gas.
I don't think its really gonna be worth trying to raise the compression with those heads. It would be better to just find some 64cc chamber 35 heads if you want to raise the compression.
Car: 1987 iroc z
yeah i was going to get the rebuild kit with new pistons since i need to put new rings in it i prolly just get the kit without the pistons and get some good aftermarket heads later. what would be a good cam to use right now for it. the motor had roller lifters on it when i got it not sure witch brand or ratio and im going to pull the cam tommaro to see if its the stocker the motors been rebuilt befor you can see the hone marks in the cylinders. the rocker says E 150 on the top
Car: 82 Z28
Transmission: TH350
So does it have roller rockers and roller lifters?
Why do you need new rings?
I'd say just find some 64cc heads for $100-150 swap those on, add a comp XE262 cam and leave the rest alone.
Car: 1987 iroc z
no it just has roller rockers not lifters they guy said the motor was smoking when he put the new one in.
Car: 86 trans am
Engine: 350 cid from a 69 chevy truck
Transmission: original 700r4
I own 2 86 fbody cars on the first car it has an unknown engine in it the block numbers are 3970010, and the heads are 3998993.
can anyone tell me what kind of hp and torque this engine putts out and are the heads any good?
Car: 82 Z28
Transmission: TH350
You probably have around 150 hp. The 993 heads are a little better then the 882 but not by much. They have 74-75cc chambers, and have a light heavier casting. Neither are considered anywhere close to performance heads. Get rid of them asap, and get some 64cc heads, your compression will thankyou. Or if the budget allows get some aftermarket heads.
Car: 1987 iroc z
i was thinking of some sportsman 2 heads i want to really get the motor to run 12's i could do this with these heads without porting couoldent i beacuse i heard that the exuast on these heads are a little weak.
Car: 82 Z28
Transmission: TH350
Probably not all the world heads suck out of the box, they really require porting to even be worth running. But once you pay for that if you can't do it yourself your up there in some really good heads. I'd definitely go with something else.
Edelbrock makes some decent aluminum heads for less than $1000. But i would suggest some Dart Iron Eagles or something around there.
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
World Product heads suck out of the box?? lol.. ME Leigh, you are completely wrong.. How many times have you run them?? This is clearly misinformation.
You shouldnt be messing with peoples money like that, thier Sportsman II's are easily good for 12's on a 350.
Car: 82 Z28
Transmission: TH350
Actually you are kinda right they are decent, my statement was more aimed towards the S/R and S/R Torquer heads. But the Sportman II's still don't flow anywhere near a "good" head. They only flow 240cfm out of the box max.
Hotrodboba400
12-10-2019 07:07 PM
92projectcamaro
01-18-2016 08:00 AM
