I wanna shorten my throttle cable so the throttle response is nicer.
1 Post
I hate toeing my throttle pedal...
How do I do I shorten it? Is there a way I could lube it up/replace it so that the pedal feels better... is there any certain calibration imparted on the throttle cable?
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
well you would just want to make sure its not TOO short and stays open, other then that u should be ok
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
- David
![](http://members.home.net/rickemard/burnout.gif)
Car: 4
Engine: 6
Transmission: 5
I don't think there's any way to "shorten" it, as such; but you might want to look at the brackets at both ends of the cable and see if you can bend them to adjust the height of the pedal to where you want it. Just make sure that it still opens all the way when you stand on it (number one cause of mystery "low ETs") but doesn't bind against something either.
ICON Motorsports
ICON Motorsports
TheTraut88
09-07-2015 05:22 PM
