Has anyone built a 388 w/3.80 crank?
Car: 1992 Camaro RS
Engine: 5.7
I guess a 350 block is used?, but what size rods and pistons? can you use 6" rods?? It is 5 more cubes than the 383.
Thanks!
Dave
My Website
92 RS, 350, Street & Performance MPFI, TFS heads, Stock crank and rods, Fordged flat tops,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Est. 365Hp 420+Lbs.
Thanks!
Dave
My Website
Crane Rollers,
Est. 365Hp 420+Lbs.
6" rods shouldn't be a problem, just make sure you buy pistons made for 6" rods and not the more common 5.7, and bring lots of money.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
I though a 383 was a 350 .030 over adn a 400 crank (and the rest)
and a 388 was the same but 350 .060 over.
am I wrong
Gimme a yes or no or explain if im close??
1989 Trans Am GTA - Flame Red Metallic, L98 5.7L TPI, TH700-R4, T-Tops, 3.27, 9-bolt rear, dual cat
- K&N Air & Oil Filter
- Dynomax muffler
1992 Camaro RS - Hawaiian Orchid, LO3 5.0L TBI, T-5, T-Tops, 3.08, 10-bolt rear - Sold
- L69 Dual Snorkel
am I wrong
- Dynomax muffler
- L69 Dual Snorkel
Car: 1992 Camaro RS
Engine: 5.7
If you did make a 388 which is .030 over what if you bored it to .060, would that be a 393??
I think your right about the .060 over 383 being 388.
Which would make more power/torque:
3.75 + .060 = 388
or
3.80 + .030 = 388
My Website
Crane Rollers,
Est. 365Hp 420+Lbs.
3.75 + .060 = 388
or
3.80 + .030 = 388
My Website
Crane Rollers,
Est. 365Hp 420+Lbs.
