Lingenfelter 219 cam w/ what heads?
Car: 1993 Corvette & 1987 T/A
Engine: LT1 - 383ci & LG4 305 Stock
Transmission: ZF6 & 700R4
A friend of mine is selling me a 350 4 bolt roller motor shortblock that has stock crank and rods with Keith Black hyper pistons. He's also selling pro magnum comp cam 1.6 rockers and roller lifters. I'm looking at the Lingenfelter 219 cam but dont know what heads to go with. I'm looking for 9.5 or 10:1 compression due to it being carbourated. Me mentioned that if I put 64cc heads on there, it would be about 11.5:1 compression, and that I should go with 76cc heads. Any suggestion for heads? Anyone else running this Lingenfelter 219 cam?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
So the motor has dome pistons? If they are flat-tops with a 64 cc chamber will put you right in your desired compression range.
Probably...I'll find out for sure. Knowing him, being a hardcore racer, I bet they have a dome.
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm running a 383 with the Trick Flow heads and the 1.46 duel spring .600 lift springs. Also using the 219 cam with the 1.6 Pro Mags and a LTR setup. Its a nice running car.
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
When I had the 219 I used AFR 190 heads milled to 58 cc for 9.8-1 CR. It was a nice street setup that got me easy mid to low 12s.
Car: 89 Formula 350 WS6
Engine: 383 miniram
that cam was designed for the LPE L98 ported vette heads which have a very high e/i flow ratio. very nice heads but too expensive imo unless you find a great deal on a used pair like i did.
