Quick question (oil change)
Old 07-23-2005, 07:18 PM
chomp's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
I'm gonig to change my oil today or tomorrow. What oil should I use and how much? Also, which filter?
I have a 92 Camaro with a 305 tbi...
Old 07-23-2005, 08:12 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
5 qts is the oil capacity for a stock pan.
I usually use 10w-30 because it's hotter here in California, not as thick as 5w-30.
And I usually use AC delco filters, haven't failed me yet, just don't use FRAM.
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
5 Quarts of Oil and you can use an aftermarket oil filter, I use a K&N filter...as for what kind of oil, i use Mobile 1 pure synthetic...but be prepared to pay between 40 and 50 bucks if you want to go with the good stuff...I belive the engine calls for 5W-30 but the Mobile 1 that i used was 10W-30...
red90bird's Avatar
Car: 1990 Firebird
Engine: 350 tbi
5qts valvoline max life. and a good (not fram) oil filter.
edit: wow my compter must be really slow
Old 07-23-2005, 09:21 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Yep, everyone here is right on. These cars take 5 quarts of oil, stick with either 5W-30 or 10W-30, and get a good quality oil filter (good brands generally include AC Delco, Mobil One, K+N, Pure One, just stay away from FRAM).
The oil brand and kind is really up to you. You can buy regular dino oil, a synthetic blend, or a full synthetic. Everyone has their own opinion on what's best.
Old 07-24-2005, 09:58 AM
chomp's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
What about 10W-40? I live here in california where it's pretty hot.. especially right now.
It seems like in the past I've run 10W-40 but im not sure...
Old 07-24-2005, 02:50 PM
Benm109's Avatar
Engine: 305 TBI
I can't really see any problem with that.
Old 07-24-2005, 11:52 PM
kyles88bird's Avatar
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
i use a 10w-30 and a napa gold filter(only filter we stock being we get make 2 cars the whole year who use i think is 1069 filter.)
Old 07-25-2005, 02:10 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I put 1 quart in the oil filter before spinning it on, and 4 quarts in the engine, same thing, 5 quarts.
Old 07-25-2005, 02:18 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
I can get Fram here, through the motor trade, sorry if this has been asked before, but whats wrong with them?
I use Mann filters daily, but have used Fram [and many others] over the years without a problem.
Is it quality, rate of flow or what?
Old 07-25-2005, 04:49 AM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Don't use 10W-40, as the additives used to create such a large difference between cold and operating viscosities tend to make the oil break down much faster than 5W-30 or 10W-30. In fact, I've heard some manufacturers specifically stating not to use 10W-40 in their vehicles because of this.
10W-30 is actually thicker than 5W-30 at cold temperatures. Once it reaches operating tempertures, they both have the same viscosity.
If your engine is in fairly good condition (no known oil leaks or problems), you might try making the transition to synthetic oil. No need to go into all the details since it's been covered too many times on this forum alone, but basically it is superior in every way to conventional engine oil.
The big issue with FRAM is the fact that some of their filters are made with carboard internal peices that are held together by glue inside the filter. This is a known fact. Many people claim to have had the filter break and send chunks of glue and carboard into their engine, but I have yet to see actual proof of this happening, even despite the fact that so many people have reported problems with their filters.
I personally use Mobil 1 SuperSyn 10W-30 in my 305 with an AC Delco PF35L oil filter. For $30 total, I figure that's about the best oil change you can give your car.
Old 07-25-2005, 07:33 AM
R1UK's Avatar
Engine: 302
Axle/Gears: 3:73:1
I like Mobil 1, used it for years, and it keeps an engine spot on, no sludge or deposits, just most customers wont pay the price for your average car. Its about £25 [$43.46] for 4litres, [or under a gallon if you prefer], and as most average cars are over that, you need another bottle, plus the filter and parts etc.
Thats interesting about Fram, never seen or read\heard about any problems, but lets face it, you dont want that to happen even once.
happyhapka
08-15-2015 04:42 PM
eightsixseven
08-14-2015 03:09 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
jahblah
08-12-2015 05:54 PM
Quick Reply: Quick question (oil change)
