car wont start need help quick!
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
ok worked one second then turned it off and didnt start the next time...It does not crank, i pulled the code and it was code 54(fuel pump relay) but i pop started it by rolling down the hill and it started and ran fine...in conclusion i dont think its the fuel pump bc i drove it and im not sure why it wont crank any ideas? i already bypassed the VATS awhile ago with a resistor. plz help
Car: 91 Camaro
Engine: LO3 305 TBI
Ok just tested the starter and its good..so what are my other possibilities...im guessing somthin along the lines of the VATS but ive tryd bypassing the starter relay also and still nothing plz someone help
Car: 89 IROC & Formula, 86 6000 STE
Engine: TPI 350's, 173ci
Transmission: TH700, TH250
Try the ignition switch and neutral start switches. Check all wiring to the starter for corrosion, loose connections. Get the frosting off the battery cables!!!!!!!!
Car: 91 Camaro
Engine: LO3 305 TBI
clutch safty switch works..no corrosion on battery or starter cables..im trying to trace back the purple wire from the starter. and how do i check the ignition switch?
Are you getting 14 volts @ the starter? Check the ignition switch by removing the cylinder and inpecting for damaged wires. Also get a multi-meter and ohm the switch.
There you have it glad ya got it. Didn't know you had an aftermarket security system on it that kills the ignition.
db057
08-11-2015 10:11 PM
