Can I just use silicone for my oilpan gasket?
Can I just use silicone to make the gasket for my oilpan? I'm 0-2 on getting the stupid gasket to seal properly, and want to stop the figgin leak.
82 Camaro:350, Erson cam, ported heads,Comp Cams 1.6:1 rocker arms, Edelbrock Performer RPM intake, Holley 600cfm, Crane Hi-6 ignition,
TH350 tranny with 2500 stall, Eibach Pro Kit, SLP 1 3/4" headers with 3" Flowmaster exhaust
No, not if you mean "don't use a gasket, and silicone only". Where's it leaking at? You do need to lay it on somewhat thick where the pieces join in the "corners".
You're not over tightening are you? The torque required to seal is pretty low, once you see the gasket "squish" out, it's usually too tight.
You can run a bead on both sides of the gasket, makes a mess to try an clean when you remove it...but if it seals and doesn't leak...it'll be a looong time before you pull it again
Shoulda used spellcheck
[This message has been edited by 8Mike9 (edited September 24, 2001).]
1 Post
Car: yep
Engine: uhuh
Transmission: sure does
IIRC you can get one piece oil pan gaskets for just about any year SBC. They are trouble free.
Definately don't just use silicone.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Car: 2006 Silverado 1500
Engine: 5.3L
you can use just silicone, but it will leak. i'd recomend using just the one piece gasket. it's available from autozone and other places like it. use no silicone with that.
