Could this be the problem? ------>
1 Post
Car: 92 Formula
Transmission: A4
I have a problem with a squealing noise at mild acceleration, and at stoplights....
I replaced the belt, and realized that the noise is coming from underneath the car, towards the rear of the engine, mid tranny.... cant tell exactly.
Could the flywheel, or the torque converter have anything to do with it?
Anyone got a clue?
(the formula)
http://kiztope.50megs.com
92 Pontiac Firebird Formula 5.7/A4
K&N, nothing else yet!
92 Rs 3.1/T-5
Beautiful car, several mods, but now I am turning attention to the 'bird!
AIM : Theonekiztope
ICQ: 8787542
"Maybe one day life will take a turn. When it does Lean into it!" Leon Calrinsky (98)
Can't help you with your problem, but I'm glad to see that you found a car. Where'd you end up finding it?
82 Camaro:350, Erson cam, ported heads,Comp Cams 1.6:1 rocker arms, Edelbrock Performer RPM intake, Holley 600cfm, Crane Hi-6 ignition,
TH350 tranny with 2500 stall, Eibach Pro Kit, SLP 1 3/4" headers with 3" Flowmaster exhaust
1 Post
Car: 92 Formula
Transmission: A4
It has given me a little trouble since I got it... Pain in the butt so far, but hopefully I will work out the kinks pretty soon... Then I'll bring it out to Compass...
I actually bought it from a guy in Angleton.. (about 30min S of houston...)
Anyone know whats up with it?
I hope you do not have the same problem I did on my wife's station wagon. Same symptoms, occasional squeling at stop lights and at certain throttle positions. I pulled my oil pan only to find she had spun a rod bearing. The two halves were overlapping each other, so there was no knock. After driving it for awhile like that the oil started become very metallic. Nice and shiny. I hope that is not your problem.
When you step on the clutch does it go away?
If it does then we have the same problem. I have not look into it yet but this happened when I had a mechanic replaced the clutch. Now I don't let any other person touch my car. I just come here and get some Ideas. Let me know if you find the cause.
1 Post
Car: 92 Formula
Transmission: A4
No clutch.... its an auto.....
I hope and pray that it isnt a spun rod bearing..... geez.... I still havent taken it apart yet, prolly this weekend.
