dam.... blowing smoke
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
My friend was following me on the hiway and said that when i accelerated hard, smoke wouldcome out of my tail pipes. He said it was a large amount.... equivalent to doing anice long burnout, but no, i was not burning out.
I have a bad exhaust leak on thepassenger side of the block... could thesmoke coming out be because thatone side of the block is runninglike **** becuase of the exhaust leak and the other is running properly? IDK if it matters, but my fuel pressure is a shade below 50psi.
I blow a little bit of white smoke on startup if the car is sitting over night... is it related to that? Is my motor dying on me / getting tired with 110,000 miles?
Any ideas?
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, MSD 6A, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's
1989 Chevrolet Celebrity Eurosport
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Any ideas?
2.8 MPFI, no mods
Car: 1989 IROC-Z
RS,
There is definetly not coolant ON the motor... the smoke was coming out of the tailpipes.
Maybe you meant IN the motor... that would be something to check for. However, if there was coolant leaking into the motor, wouldn't there be smoke coming out at a much more constant rate? I only get white smoke out of the tailpipes on hard acceleration. Hmmmmm
white smoke in the morning is not smoke but steam from condesation in the pipes. When your friend was behind you what color was the smoke. if it was blue then u are burning oil. If the smoke was black the car was runing rich
86 IROC-Z
305 TPI
th350
flowmaster exhaust
chip
86 IROC-Z
305 TPI
th350
flowmaster exhaust
chip
Car: 1989 IROC-Z
When my friend was behind my on the hiway, I blew white smoke out of the tailpipes.
How is your car running. I think what people are getting at is that you may have a head gasket problem. If you are burning any coolant and there are no leaks then this could be. Most likely the smoke at startup is from bad valve guide seals, a common problem that most of the time would only cause smoke at startup. Did you car downshift when you hit it and your friend saw smoke? If you hit it and it downshifted into high rpm, sometimes bad valve guide seals can make it smoke for a second, but not a stream of smoke. If it looked like a burnout and the smoke was white I would check your coolant level and make sure you werent burning anything.
good luck
-'85
good luck
-'85
