How many times does the engine fire in one revolution?
How many times does the engine fire in one revolution? Do all 8 cylinders fire in one revoultion, just one, or somewhere in between?
82 Camaro:350, Erson cam, ported heads,Comp Cams 1.6:1 rocker arms, Edelbrock Performer RPM intake, Holley 600cfm, Crane Hi-6 ignition,
TH350 tranny with 2500 stall, Eibach Pro Kit, SLP 1 3/4" headers with 3" Flowmaster exhaust
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
So to answer your question a bit better, A 4 stroke V8 will have a cylinder fire every 90 degrees of crankshaft rotation. This means in one revolution of the crankshaft, 4 cylinders will have fired.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
