305 Failing
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
305 Failing
305 Sounds like it is rumbleling, and I know my starter is going to give out soon due to the fact that it fails to start on random attempts (making a "tik tik" sound) also when I turn off the car it takes about 4 seconds to fully turn off when the key has already been rotated and removed to the off position. The Tempature fluctuates, the RPM's stay well below the "10" margin. Usually when it is running normal it idle's at "10".
What should I do? Which parts need to be removed? and or replaced??? This is my only car. Please help me!
