Slight thump in 1-2nd gear ONLY
Alright, my friends 2.8L 89 RS has a really light thump on his consol whenver hard accelerating, now i told him that it is probably a tranny mount, but its weird because it will ONLY thump when shifting from 1st to 2nd, 2nd to 3rd it doesn't make any noise, and the thump isn't loud at all, its sounds more like a person hitting on the bottom, very weird sounding. Do you guys still think its a tranny mount, or maybe just the bolts are loose, cause its a muffled thump.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
- David
![](http://members.home.net/rickemard/burnout.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
why not get under the car and look at the trans mount and see if it's broke?
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
1 Post
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
someone asked bout the same question on another post. to check the tranny mount jack the car up, then put the jack under a solid part of the rear of the tranny and raise it some and see if the mount pulls apart, it is sometimes hard to see if the mount is bad with it in a rest postion. and it may only do it from 1-2 shift cause of the gear drop from 1-2, and most transmissions i have seen shift harder 1-2 than 2-3 which would make the tranny jump up more. hope this helps. lil jay
Wide Open Till You See God...Then Brake
<font face="Verdana, Arial" size="2">Originally posted by Hulk0202:
Thats probably because the monster 2.8l doesnt have enough torque to slam the tranny into the floor on any other shift.</font>
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
![](http://home.adelphia.net/~coolj88888/Burn.gif)
My IROC In Readers Rides
My IROC
[This message has been edited by IROCThe5.7L (edited September 23, 2001).]
rudolphschenker
09-04-2015 02:41 AM
UltRoadWarrior9
09-02-2015 08:24 PM
