Clear gear casing for electronic hatch
Can I order this part? It's cracked in half and the gears aren't locking together so my truck won't shut..The motor just spins..I tried gluing it but I don't think it's going to hold forever.
I am looking to buy Edelbrock T.E.S. headers with the y-pipe. I am also looking for a 3.42 - 3.55 posi disc rear. cheesy@fred.net is my e-mail, send a letter if you can help!
- Red '88 IROC 305 TPI T-5 w/3.08
- Accel 300+ Ignition
- Accel 300+ Pro Sleeve Plug Wires
- AC Delco Rapid Fire Plugs
- Dual Friction Stage III Centerforce Clutch
- Energy Suspension Transmission Mount
- Flowmaster Force II 3 Chamber Cat Back Exhaust
- Gutted Airboxes
- Hypertech Stage II PROM
- Hypertech Airfoil
- Throttle Body Coolant Bypass
- Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
- Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
- Best 60' 2.163(Florida)
- TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
- Aluminum Driveshaft (Installed after Maryland run)
Yes, all of the parts are available, or at least they were a year or so ago when I needed them. I got the part numbers from a post on this site, so it may still be in the archives somewhere.
ambainb
04-25-2016 09:21 PM
